96 LX - brake lights will not turn off
Old Feb 25, 2013 | 12:39 PM
SirJohnIII's Avatar
Default 96 LX - brake lights will not turn off
Noticed that my brake lights where still on after I got out of the car today. Found some pieces of some blue plug or stopper thing on my floor board but could not figure where it came from. Ended up pulling the fuse so my battery would not die.
Any ideas?
Old Feb 25, 2013 | 12:48 PM
Check to see if your brake stopper pad is still there.
Brake lights stay on...how I fixed them - Honda-Tech
Old Feb 25, 2013 | 12:57 PM
SirJohnIII's Avatar
nope...that must be the blue thing that is in many pieces.
What is a good idea for quick fix?
Old Feb 25, 2013 | 01:05 PM
SirJohnIII's Avatar
Bingo....found a bolt to fir the hole on the shaft and it works...going to have to find a nut to keep it on though
Old Feb 25, 2013 | 07:24 PM
Suggest getting the proper plug...hey it lasted ~17 years. If nothing else the OE plug will give the proper setting for the brake switch. If you go for the rig then know that the cruise may not work.
I've bought the OE plug from a local dealer for $2.15 plus tax. One minute install and done OE PN 46505-SA5-000
Note the new ones from the dealer are white.
Attached Thumbnails 96 LX - brake lights will not turn off-pedal-plug-broken.jpg
Old Feb 26, 2013 | 03:28 PM
SirJohnIII's Avatar
Im going to get the replacement for sure but at the time I needed a fix for it quick and it worked.
Old Feb 26, 2013 | 05:11 PM
Oh, don't get me wrong.....I've used all kinds of things as a temp fix until I could get the plug....last time I was there I just went ahead and bought two as I figured one of my others would go at some point...and it did, wasn't the brake one but one of the ones on the clutch pedal.
kennilope
Jul 15, 2022 12:21 AM
Gangsta101
Feb 10, 2013 01:50 AM
glenn77539
Jul 9, 2012 12:04 PM
Mzanuel513
Nov 15, 2007 05:14 PM
