Brakes and Normal Maintinence
I just recently changed out my front brake pads and everything seems to working fine accept in the morning I noticed when I start the car and press on the brake pedal I hear a clicking noise coming from the center console near the gear selector, then after a while the noise goes away. Any ideas what is causing this? The noise was never there before I changed the pads.
Also my car has 180,000 miles....What would you recommend replacing or maintinencing? I tow a jetski with this car so I am trying to get it ready for the season. I have bought the KYB GR-2 struts for the rearandI am now looking for a heavy duty spring. Any help or reccomendations would be greatly appreciated. Thanks.
make sure your suspention components are all in good order, maybe synthetic oil, make sure all fluids and filters are good as well, tires properly inflated. Have you had your timing belt replaced? other than that you should be good to go. jetski's I dont consider to be "heavy towing"
depending on your driving habits, like if you do primarily stop and go city driving then go ahead and change it, but if you do a combo/more highway driving you should have another 20k before you need to change it.
alphaney
Feb 12, 2022 10:14 AM
ozman05
Jul 10, 2007 10:14 AM
thunder_x
Sep 27, 2006 11:00 PM
