Break lights work, sort of
Old May 11, 2022 | 09:37 PM
AgonizedHonda's Avatar
Default Break lights work, sort of
So I have a 2000 Honda Accord ex, it’s a 2 door coup with the V6. My break lights turn on when I turn my headlights on, but when I push on the brake the lights don’t get any brighter like they used to. I’ve checked fuses, changed the bulbs, checked the brake switch behind the peddle, still nothing. I don’t have any lights on my dash. Am I missing something to check?
Old May 12, 2022 | 11:11 AM
rockhoundrob's Avatar
You may have a grounding problem or an OPEN on the brake wire.
If you have a volt meter, take the bulb out and check that you get voltage on the brake light contact when someone pushes the brakes.
Are you SURE the brake switch in the pedal is good?
Old May 24, 2022 | 07:09 PM
double checked the break light switch. The pin inside of it was destroyed, fixed that issue. Thanks for the tips tho
motorhead1959
Aug 20, 2020 01:34 PM
kazeuchia
Oct 23, 2017 12:02 PM
bjr001
Apr 2, 2013 08:33 PM
dragonman80917
Mar 12, 2012 03:33 PM
htrawick
Dec 17, 2011 09:18 AM
