Bright Orange Coolant?
Old Jul 1, 2009 | 08:19 AM
guinnessmike's Avatar
Default Bright Orange Coolant?
I have a 89' Accord that I bought about 6 months ago. When I got it I noticed the coolant was this bright orange-rust color but the car had other problems that needed more attention. A friend told me it was prob some of that stop leak stuff. 2 months later the radiator started leaking (I know you are shocked), so I got another radiator from a yard and drained and refilled it 3 times (letting the car come to temp each time) and thought I got all of it out. Since then I have had to add about a quart of coolant two times and it is bright orange again. I can't seem to see any leak and there is no coolant in the oil. Any ideas on why the discoloration or where to look for my lost coolant?
Old Jul 1, 2009 | 08:28 PM
It might be a chemical reaction due to leaking head gasket allowing contamination of coolant w/ exhaust gases and loss of coolant. There is a chemical test available to detect exhaust gases and gasoline in coolant. Try the test.
Other symptoms of leaking head gasket are engine missing on a warm re-start, steam (white smoke) vapor in summertime, possible oil contamination (yellow-white scum on dipstick and valve train), and overheating and bubbles in overllow tank.
Old Jul 2, 2009 | 01:50 PM
I have no other symptoms of a leaking head gasket (thank goodness). I will probably try that chemical test though. Do you have any idea where to get it or what it is called exactly?
Old Jul 2, 2009 | 02:56 PM
deserthonda's Avatar
could be a very rusty block...........have a shop do a full coolant flush using using the machine
as for losing coolant,, have them pressure test the system before doing a flush
AUTO Design
11
Dec 22, 2011 11:31 AM
Codycancatch8
Jul 4, 2011 09:45 AM
dre707
May 18, 2010 05:52 PM
Smudgie
Sep 2, 2009 06:35 AM
accord5g
Aug 23, 2006 07:39 PM
