Broken door Locks
Old Jul 22, 2011 | 07:40 PM
poynterandy's Avatar
Default Broken door Locks
So my door locks were broken so I replaced the actuator. While replacing the actuator I ended up breaking the plastic piece that the actuator clips onto that operates the door lock pins. So when the actuator works it has nothing to pull on to lock and unlock the doors. Anyone know what the name of the piece that it clips onto is called? Having some trouble finding the piece so I can replace it.
Also, in doing the above I ended up messing with the window tracks, and now my window is slightly off track. enough to see a tiny sliver of sky at the top left corner. Not noticeable unless driving down the highway and you hear the wind. Any ideas on how to fix that?
Old Jul 22, 2011 | 07:47 PM
Get a 94 accord shop manual. There is a link for manuals in the common DIY thread at the top of the gen tech help forum. That shows how to adjust the window.
I can't remember what the actuator bolts to. Here is the parts blowup from online OEM parts sites. 8 or 36 is the actuator. I might bolt to the latch assembly.
smiyares
May 24, 2017 07:39 PM
navyned
Jan 24, 2012 07:32 AM
sanchdaniel
Jan 23, 2008 10:01 PM
gtrrambler
Aug 16, 2007 08:34 PM
PaulVidal
Jan 17, 2007 10:03 PM
