Broken Lug Bolt on 2000 Accord LX
Old Oct 25, 2011 | 08:58 PM
mike.stribling's Avatar
Default Broken Lug Bolt on 2000 Accord LX
So today I was taking my wheels off to replace the brake pads and I broke off the lug bolt on the driver side wheel.
I've read a few places that it's a pain because you have to take everything apart and then I've also read that you can take the 2 screws off and pop the plate off and that gives you access to remove the bolts. Which is right?
Would it be possible that I could just remove the screws?
Thanks for the help!
2000 Honda Accord LX Sedan 4 Cyl
Old Oct 25, 2011 | 09:14 PM
This thread may help you if it is the front wheel:
https://www.hondaaccordforum.com/for...acement-42911/
Old Oct 26, 2011 | 11:33 PM
That is the info I needed! Thanks!
I need to borrow my friends grinder tomorrow.
How long do you think I can drive on it and how safe would it be? I need to get to and from work tomorrow and then I can fix it after I get off work. Would it be safe to do? Would it bend the rotor at all?
Thanks!
Old Oct 27, 2011 | 06:26 PM
You should be ok.....as you are driving remember one is missing so no wild corners, bumps, ect......
orzechNJ
Sep 4, 2012 02:47 PM
2000accord_coupe
Sep 29, 2008 12:39 PM
HORSEPOWERJUNKIE2007
Sep 2, 2008 08:02 PM
jkellyre
May 15, 2007 07:39 PM
Tommy997
Jul 26, 2006 02:14 PM
