Broken Studs
Old Sep 1, 2006 | 08:35 PM
Island Accord's Avatar
Default Broken Studs
Hi, I have a 2001 Accord LX 4dr 4cyl and I was wondering if anyone had trouble with their wheel studs. When I say trouble, I mean them stripping/breaking off.
The reason I'm asking is because this is the 3rd time I need to replace them. I already had to replace all 8 studs on the front (1 broke on each side, so I just replaced them all). Now, one of my rear studs stripped & I'm thinking of just replacing all the studs on both sides.
My good friend has a '99 Accord LX 4dr 4 cyl and he also had to replace the 8 studs on both sides (front).
Could it possibly caused by my rims? I have a 17in Racing Hart C2's on it, but the problem happened to my friend even before he slapped on his 19in rims.
Is it only our cars or has this happened to anyone else? Anyone have an explanation to this? Please help!
Old Sep 1, 2006 | 08:43 PM
Chiovnidca's Avatar
Default RE: Broken Studs
It's not a common problem. Usually caused by overtightening the lugs.
Old Sep 1, 2006 | 08:52 PM
I don't really tighted the lug nuts too tight, just "hand tight," but not too loose. Tight enough to keep the rims on the car and not loose for them to come off.
As to the shops, they use impact guns that make the lug nuts way too tight to take them off. So, I'm thinking overtightening is out of the picture. Thanks for responding though.
Old Sep 1, 2006 | 10:18 PM
Chiovnidca's Avatar
Try torqueing them to 80 ft-lbs. You'll have fewer problems.
Old Sep 1, 2006 | 10:59 PM
mbo1985's Avatar
sounds like overtightening to me too. Those impact wrenches will overtighten them real fast...
Old Sep 2, 2006 | 02:02 AM
How do I know when it's torqed at "80ft-lbs?" Remember now, I don't know too much about cars.
Old Sep 2, 2006 | 03:12 AM
You have a torque wrench in your tool box? If not ...then go to AutoZone and rent one, they will explain to you how to use it...
ORIGINAL: Island Accord
team_lunatics
Mar 17, 2011 05:21 PM
sofireguy
Apr 21, 2009 09:28 AM
powerpeecee
Jun 6, 2008 07:17 PM
pj150
Oct 15, 2007 10:58 AM
WhyNotFab
Oct 20, 2006 02:06 AM
