Bubbling Noise
Old Oct 13, 2007 | 09:03 AM
kingsham
Default Bubbling Noise
I have a 1993 Accord 10th Anniversary Edition.
For some strange reason, after i turn my car off, I heard this bubbling noise. I dont know what it is. I replaced my radiator a few years ago, so i know its not that. My thermostat doesnt read hot, so im pretty sure its not that.
Can you help me out?
Old Oct 13, 2007 | 10:23 AM
sir_nasty's Avatar
Default RE: Bubbling Noise
Check your coolant level and then pop the hood after you turn off the car and there is a hose that goes from the radiator to an overflow bottle VERY CAREFULLY look at that and I bet the noise is coming from there. Let the car cool down, top off the radiator, maybe put a little bit in the overflow bottle (as long as it's below the max fill line). If the problem persists and the car is not overheating you may have a bad radiator cap
Old Oct 15, 2007 | 01:15 AM
Planefreak's Avatar
My brother had that happen to him one time. If you aren't running enough anti-freeze, or just pure water, it could be boiling off.
Old Oct 15, 2007 | 08:57 AM
finch13's Avatar
This is way out there, but my car makes a bubbling noise when I turn it off after the A/C has been running... the noise comes from the passenger footwell.
Old Oct 15, 2007 | 11:54 AM
Finch, yours is the AC refrigerant continuing to flow through the evaporator. That happens until the high & low side pressures are equalized.So if kingsham is hearing this sound, it's normal.
bill790
Jan 31, 2021 03:12 AM
Meter an
Jan 3, 2017 04:22 PM
Cody_754
Aug 30, 2011 11:53 PM
Sauce
Feb 22, 2007 11:31 AM
atwood
May 1, 2006 08:59 PM
