bubbling noise in ac unit
Hey i just now noticed a bubbling type of sound coming from the ac unit,
its a 2001 honda accord ex with the climate control, it stops and then starts up again its annoying to say the least lol, anyone know of this problem
Check that water drains from the evaporator drain line when AC is engaged. Low humidity can sometimes make this difficult; too little moisture to cause a drain. Hadrly ever have that problem in Houston. If no water draining, you may be accumulating enough water to hear the water sloshing around inside the evaporator housing.
I've also heard some hissing/gushing sounds from evaporator when charges begins to get low. When compressor cycles off the system equalizes pressure across expansion valve and noise is generated.
are you sure the noise is coming from the a/c compressor? have you checked your radiator overflow tank/coolant level lately to make sure that it has nothing to do with that?
is it during operation or afterwards when you turn it off? if it is afterwards it's normal as the pressure equalises the in system.....my home ac unit does that all the time
we had same kind of issue in a few earlier cars 94-95 ,while under warranty , what we did was to evac the a/c system and keep it under vacc for 3-5 hours then recharge it ,, that tip came straight from honda tech line ..
it might be a waste of money and time but you might want to give that a shot ,, without any of us hearing the actual noise it is kind of hard to diagnose properly
Queen eiko
Jan 24, 2010 12:09 AM
