Bypass heater hose repalcement 1991 EX
Old Oct 4, 2011 | 08:34 PM
I think that I am wrong. I thought that you were talking about the hose clamp for the two big radiator hoses.
Old Oct 4, 2011 | 09:01 PM
John-yes, sorry shouldn't have put it that way. But when under the t-stat and fighting even getting to them, sometimes getting the lock vs just getting the dang thing "open" can be a pain...I'll edit.
EDIT:No John-you are correct, even the small ones can lock..just a PIA. I just saw you last post.
Old Oct 4, 2011 | 10:27 PM
Honda_Lady's Avatar
i will look at my 4th gen tomorrow and try to help you with this Iswpubrw. i haven't had to do that hose on mine yet but will definitely do what i can to help.
Old Oct 5, 2011 | 11:12 AM
lswpubrw's Avatar
OK looks as if my hoses have two different types of "factory" hose clamps. A few of the larger ones have a "male" tab with a bend it that can hook into the "female" tab. Most of them, especially the small ones, just have a straight tab which can "mate" with the hollow but not stay hooked. It is a 20 year old car so who knows what's factory original and isn't. I was able to confirm the leak is in the "U" hose that bypasses the thermostat. It is a pin hole right at the hose clamp. I will work on getting this hose off and replace it using the worm style clamps.
BTW this car has a radiator cap marked with 11 on the tab even though everything I read says the PSI should be between 14 and 16 lbs. However when I try 16 lbs, I start springing these leaks. Is there any problem with running the 11 lb old radiator cap?
Thanks,
Bob
Old Oct 5, 2011 | 03:33 PM
lswpubrw's Avatar
I changed the hose today, it was doable from the top with some long handled, 90 degree bend needle nose pliers. Got it together and sprang a leak on the small hose that goes into the air chamber under the throttle body. Replaced that one and for now all is tight. I'll keep a close eye on the other small hoses and if a leak developes somewhere else I'll just change out all the hoses I haven't done yet.
Thanks for all the suggestions,
Bob
Old Oct 5, 2011 | 07:01 PM
Glad you got it...thanks for getting back.
BTW-let me guess the "bigger" end of the hose had the locking and the smaller did not...now that I think a little more, at "some" size they went from locking to squeeze.
Hope you were able to position the worm clamps to make re-assy easier?
Last, if you didn't-I would suggest bleeding the air out of the cooling system just to be sure.
Old Oct 6, 2011 | 06:59 AM
  #17
lswpubrw's Avatar
Yes the larger radiator hose clamps all have the locking feature, everything smaller does not. One end had more open room around it than the other. The tighter one interfered with the manifold so I used a spring type clamp on that end, worm on the more open end. Wife used the car last night and returned with no leaks!
Yes I bled the thermostat after the warm up. That's a nice feature. I have an older (1985) MB diesel and bleeding is much trickier.
Bob
Old Oct 7, 2011 | 11:57 AM
  #18
About that radiator cap... look for a decimal point. Honda caps are marked in bar. I bet it says 1.1 bar = 16 psi.
Old Oct 8, 2011 | 07:47 AM
  #19
lswpubrw's Avatar
You are correct!
A careful second look shows the decimal point. I suspect this is the radiator cap that shipped with the car 20 years ago. I guess because of the numerous hose leaks I assumed the 16 lbs. was a pressure problem and apparently it wasn't.
Thanks for the followup,
Bob
SevenFour
May 18, 2012 12:33 AM
msampson77
Aug 18, 2011 04:55 PM
Larry.Strapp
Oct 24, 2010 04:44 PM
jamesejam
Sep 21, 2009 02:37 PM
imjrk
Sep 28, 2008 01:17 PM
