A/C is blowing but not cooling
Old Nov 10, 2020 | 07:50 AM
srmirza's Avatar
Default A/C is blowing but not cooling
Hello,
I am a new member in this forum. I have a Honda Accord 2006 SE (Sedan V4) and it has 223,000 miles on it. A couple of days ago, while I was driving it suddenly stops cooling but it still blows. I thought it might be the Freon. Therefore, I bought an A/C recharger with a pressure gauge and when I measure the pressure it indicates the pressure is in the red zone on the gauge. Now, I am not sure what is wrong with it. I would appreciate any advice/suggestion.
BTW, we recently move from Virginia to Florida, not sure if this has something to do with it. I mentioned it since there is a weather difference between these two states.
Thank you,
Rafi
Old Nov 10, 2020 | 10:29 AM
Welcome.
We use the "new member" area mostly for welcome & introductions, so I'll move this over to General Tech. where more people will see it. I'm not the AC guru so probably someone else will see this & answer.
High pressure when the AC is running might be the expansion valve is plugged? It's a good thing to measure both high and low pressures and don't just add refrigerant without knowing what's going on.
Old Nov 10, 2020 | 01:48 PM
srmirza's Avatar
Thanks for your reply Jim! I have not added any refrigerant yet since it was already showing it has high pressure.
Old Nov 10, 2020 | 04:58 PM
Definitely do not add freon until you do more troubleshooting.
Start the engine and turn on the a/c. Look at the a/c clutch that is outside the pulley. Is the a/c clutch spinning with the pulley or is it stationary?
Old Nov 11, 2020 | 12:24 AM
Seanjordan20's Avatar
Also look at the relay and swap with a like one to eliminate it being an issue
Ramsey05
Jun 16, 2020 06:57 AM
John Krok
Jun 12, 2019 08:52 PM
Gescha
May 13, 2018 06:48 AM
smuphil
Apr 11, 2011 04:29 AM
haccord93
Aug 11, 2007 07:03 AM
