Engine Oil Leak Dye Kit
Old Nov 10, 2020 | 09:16 AM
saveabuckchuck's Avatar
Default Engine Oil Leak Dye Kit
Hello,
Has anyone used a dye kit to locate oil leaks? If so, could you tell me about the one you used? Trying to find the source of a leak but rather than cleaning the engine and then having to keep checking to see if I can find where the oil is leaking from, think it might be easier to use dye. There are so many choices online however, thought I would ask here first. Thanks for your help!
Old Nov 10, 2020 | 09:54 AM
I haven't used one, but I'd recommend cleaning up the oil anyway. If you don't, then I think the dye can quickly spread out through the old oil and make it harder to pinpoint the leak.
Old Nov 11, 2020 | 12:25 AM
Seanjordan20's Avatar
I've used oil dye and light to find a leak which took me a while to do on a 08 TL. Clean the engine first it will save you a lot of time
jpeeezy
Feb 23, 2013 08:06 AM
randall07
Dec 29, 2009 10:40 AM
barritron
Jul 6, 2008 04:14 PM
ayisyen
Feb 21, 2008 08:47 PM
