a/c compressor does not cycle
Old Apr 22, 2013 | 05:28 PM
olehonda's Avatar
Default a/c compressor does not cycle
00 accord EX V6. I can turn the a/c on and the display will say on but the compressor does not cycle on. The idle will change but no cold air. The blower works great and the refrigerant pressure reads 90psi on both sides of the compressor. What kind of safety or transducer might be holding the compressor out? Is this a mechanical issue with the compressor clutch? Thanks for the help.
Old Apr 22, 2013 | 06:29 PM
With 90 psi, the compressor should engage at least briefly, even w/ low charge. Check for 12V to the compressor clutch coil when AC is commanded On. If you have 12V, the compressor clutch coil is open or clutch gap is too large (most likely).
Accessing compressor on a V6 looks like no fun, but at least it's on front side of engine. A shop manual will be essential for DIY. Check youtube for videos of replacement procedure.
packfan_1982
Mar 10, 2013 04:43 PM
19962door
Jan 3, 2013 07:14 AM
birkHonda
Oct 29, 2011 07:12 PM
Christopher V. Kimball
May 13, 2009 10:44 AM
aytgy
Sep 8, 2007 03:38 PM
