A/C issue
Old Aug 13, 2012 | 05:06 PM
oldgold's Avatar
Default A/C issue
91 Accord. A/C will blow cold for 3 or 4 minutes then turns warm. Had system evacuated, refilled/pressure tested. No leaks. converted to r134a in the process. Compressor runs fine. Fans working. Drove for 2 weeks, checked pressure and it is full of freon. Any ideas? Suggestions to check? I'm baffled.
Old Aug 13, 2012 | 06:34 PM
This happens when clutch gap is too large. Also could be a weak AC compressor relay.
Diagnostic for clutch gap is to rap the clutch face w/ a stick. If clutch engages and begins to run, the clutch gap is too large.
If nothing, check whether 12V is being coupled by AC relay to the compressor lead when AC is commanded on and no compressor engagement. If no voltage, then AC relay is faulty.
tzoromski1
Oct 4, 2012 10:24 PM
Cubeman
Jul 23, 2012 12:40 PM
zZHellBlazerZz
Jun 15, 2011 10:12 AM
art vandelay
Aug 2, 2010 09:29 AM
