a/c not blowing fully & radio light not showing
Old Oct 17, 2006 | 03:40 PM
Monicalovesaccord
Default a/c not blowing fully & radio light not showing
Hi all!
I have a 2003 Accord Coupe. This a.m. when I got in, the air was not blowing to full capacity.
I could feel it a little, and it felt cold but it doesn't seem to be pushing the air out. Also my radio/clock display has been dark (I have to strain to see the time) for about a week now. I assumed that a fuse just needed to be changed since the radio still plays. I checked the fuses but could not find any blown. Can anyone point me in the right direction? Thanks so much!!
Monica
Old Oct 17, 2006 | 04:43 PM
RTexasF's Avatar
Super Member
Default RE: a/c not blowing fully & radio light not showing
Monica,
There was an issue with 2003 and 2004 Accords that caused the radio/clock display lights to go out. The enire unit will need to be replaced. Out of warranty? Honda may replace it at no charge or ask for you to pay a portion of it. The fan not blowing on high speed is a different problem.......check fuses first on that one.
Here is a link to the Honda Bulletin. Print it out and take to dealer:
http://www.driveaccord.net/forums/at...achmentid=3471
Old Oct 22, 2006 | 10:16 AM
RTexasF's Avatar
Super Member
HMMM! Monica disappeared quickly! I wonder if the link to the TSB I posted was ever even seen?
Old Oct 23, 2006 | 12:06 AM
YeuEmMaiMai's Avatar
does your fan work on the highest setting? If it does, then I would suspect your blower resistor has failed
theoutbackdream
Mar 5, 2014 08:56 AM
PJ_STYLES_95AccordEx
Jun 7, 2011 05:40 PM
kumaresh.perumal
Aug 24, 2010 10:14 PM
BHoward711
Apr 12, 2010 08:57 PM
Antarctica
Nov 17, 2008 06:25 PM
