Sponsored by:
Sponsored by:
A/c not working after changed radiator (94 ex 2d)
Old 07-11-2012, 02:16 PM
Brenton Mcfall's Avatar
Default A/c not working after changed radiator (94 ex 2d)
hello im new here... and dont know much about cars i just replaced my radiator and now my A/c is not working light comes on put on the freon and diel went to the red so i didnt put it in.... checked fuses cant see a leak please help
Old 07-11-2012, 06:42 PM
Start the car and turn on the a/c. Do both fans on the radiator turn on?
Also check your work. Did you accidentally unplug the a/c compressor? How about the fans?
Old 07-11-2012, 07:06 PM
Update: so the cluch wasnt working cause the wire to the censor wasnt all the way attached .. got that attached .. clutch engages now checked lvl of coolent with the gage that came with the freeon stuff.. its in the blue.. but its still pumping out hot air
all and yes bolth fans go on.... im at a loss
Old 07-11-2012, 10:41 PM
was the a/c working properly before you installed the new radiator?
Old 07-11-2012, 11:10 PM
Refer to post #9 in this thread to see if it is related to the heater valve.
https://www.hondaaccordforum.com/for...ter-fix-48610/
Old 07-12-2012, 09:39 AM
Yes it was ive checked all of the pluggs. there all attached , some one has told me it may be a leak some were.. cause after the cluch was activated the lines got freezing and it started blowing cold air, then it stopped and started blowing hot air..... i put a can a fre on in and it didnt change..
Old 07-12-2012, 07:00 PM
Sounds like you may have "over charged" the system.
Really suggest having the high and low side pressures checked.
Old 07-12-2012, 09:38 PM
Never just add R134a to the system unless you verify that you have a low charge. Never guess on a/c work.
Overcharging the system is dangerous, because you can create excessively high pressure causing something to burst and hurt yourself or others. You can also damage the compressor and other components which is expensive.
Old 07-13-2012, 01:56 PM
SO i figured out what the problem was i dont know how to add pictures but it was the darn *** in side the car the *** just spunn and wasnt turnig the dial under it ... after figureing that out i ran the gage test and im right at the mark for filled or not and its pummping out really cold air now
Blastingas10
12-21-2014 06:54 AM
93Accord2.2
11-06-2013 11:53 PM
Accord01gt
01-08-2012 07:40 PM
Julieanne1976
08-21-2009 09:20 PM
jenny
10-09-2008 09:27 AM
Quick Reply: A/c not working after changed radiator (94 ex 2d)
