A/C Not Working on My TSX
Old Mar 19, 2013 | 06:16 PM
You could have a wide open expansion valve, but I would have thought you could develop some differential pressure.
Can you see any flow in the receiver/drier window port? If yes, the compressor may be working and expansion valve wide open.
Damn, I need to read these posts more closely. I didn't realize it was PAH w/ the problem!
Old Mar 19, 2013 | 07:33 PM
I just went out and tried to pull off the clutch plate, but it still is attached securely. The clutch plate spins with little resistance. The site glass looks clear and I saw no air bubbles when the compressor was spinning.
Next up is to have the remaining R-134a recovered and quantified. Then I will take off one of the lines to see if there are metal shavings in it.
Old Mar 19, 2013 | 07:46 PM
It may be due to a faulty field coil (stator set). A bunch of different model Acuras and some Honda Accords had a problem with it.
Honda-Tech - View Single Post - Problem with Heat/AC on 2003 Honda Accord EX
Old Mar 19, 2013 | 07:52 PM
This Sept. 07 Acura Service News excerpt was related to the Acura RL; but, other Acuras also had the problem.
Attached Thumbnails A/C Not Working on My TSX-sept-07-news-excerpt.jpg
Old Mar 19, 2013 | 07:56 PM
Thanks redbull. The clutch is definitely engaging. I'm assuming the coil is doing its job.
Old Mar 20, 2013 | 11:52 AM
So it's likely either a faulty compressor (shaft broken, loose from driveshaft, rotor/stator damaged) or expansion valve wide open. Both alternatives seem unlikely, but it must be one of these.
Slightly hope it's a bad compressor. I think I looked at expansion valve replacement and pulled the covers back over my head (too scary!).
Gangsta101
Feb 10, 2013 01:50 AM
LaGirl
Apr 24, 2012 05:29 PM
MoDawG
Dec 10, 2009 07:00 AM
sthavorn
Apr 7, 2007 10:12 PM
arunsam3000
Mar 6, 2007 01:40 PM
