A/C oil capacity question
Old Sep 27, 2012 | 04:11 PM
Eric's Avatar
Default A/C oil capacity question
I have a 95 4 cyl. Accord. I've replaced the evaporator, dryer and compressor. If I understood the service manual correctly I need to add 40 ml or 1 1/3 oz for the evap, 10 ml or 1/3 oz for dryer. The compressor instructions are confusing to me at the least. I have a rebuilt compressor with no oil. If I understand the manual correctly I should add 160ml or 5 1/3 oz for that. So the total would be 210 ml or 7 oz. Can anyone confirm those are the correct amounts?
Old Sep 27, 2012 | 06:39 PM
A Haynes AC manual I have show much less total amount (3-4 oz total).
However, I installed 8 oz double end capped PAG in my 94EX when I overhauled the AC system w/ no problems. My take is the oil amount is not critical. I like to go over rather than low. Somewhere around 6 oz should be fine.
Check ackits.com for PAG and orings for the system.
Pull a long hard vacuum before recharging.
skramer
Oct 26, 2011 08:20 PM
bigdawg74
May 3, 2010 12:24 AM
orange_blaster
Mar 28, 2008 11:46 AM
coolgmslife
Jul 26, 2007 02:29 AM
91boz
May 24, 2007 07:03 PM
