a/c thermo switch location?
Old May 26, 2009 | 10:03 AM
IWL BCNU's Avatar
Default a/c thermo switch location?
Looks like it should be behind the glove box, but I can't find it. Anyone have any more info, 1995 Accord.
Old May 26, 2009 | 01:29 PM
I think that it is on top of the evaporator.
Old May 26, 2009 | 04:03 PM
hondadude's Avatar
well It's actually a thermistor/ SCR set up.....Should be located on top of the evap box, with 2 thin wires running around the drivers side of evap box.
Here's 2 pics that explain testing......FWIW I 've never seen one go bad.
Attached Thumbnails a/c thermo switch location?-95acctherm1.jpg   a/c thermo switch location?-95acctherm2.jpg
Old May 26, 2009 | 08:37 PM
IWL BCNU's Avatar
Thanks, I'll see if I can find it. It's the next step in testing my ac, if I ground one of the wires at the pressure switch my a/c works correctly, so it is either the thermo switch or the ecu not supplying ground to the circuit.
Old May 28, 2009 | 06:42 AM
IWL BCNU's Avatar
I was sent the wrong schematic, now have the right one and did the test, my thermo is bad, bypassed it and it ran down to 29 degrees out the vent and I shut it down.
So now, can it be easily replaced? looks like the box has to come apart, can the bottom be dropped in the car?
Old Jun 25, 2009 | 10:36 AM
IWL BCNU's Avatar
Well, finally messed with it again, the thermo switch was bad, and also a trace on the heater switch circuit board was lifted and fried. I soldered in a jumper for the board for now, and a new thermo switch, and all is good.
Old Aug 4, 2011 | 07:37 AM
deanel's Avatar
Default Where do I find the AC thermo switch?
I'm pretty sure my ac thermo switch is out on my '93 accord wagon. Do I access it by pulling the glove box or blower motor out or can I access it via the driver side? Thanks
RobinsonRicer
Jan 25, 2013 11:16 AM
Macmanjams
Jun 30, 2012 09:19 AM
Dannyboi40
Jan 22, 2011 01:18 PM
IWL BCNU
Jun 25, 2009 10:36 AM
maro
Apr 10, 2007 08:21 PM
