cabin air filter
Old Oct 25, 2010 | 07:00 PM
EXV6NIGHTHAWK's Avatar
Maybe, the filters were taken out, because they clogged up with sand too fast. ???
Old Oct 25, 2010 | 11:03 PM
darkgreen18290's Avatar
Can you not ask that they order one? Is it LHD or RHD, just for my own info. Sand on the evap can not be good, I'd worry about the heat core as well but based upon where you are if that went bad I'd just by-pass it.
Heck if nothing else I might even try to get some stocking material, I know that is bad but it has to slow down the sand.
EDIT: If you want I might be able to get detailed spec's on the filter and send them to you? Let me know, it might take a little time but I'd try.
thanks much poorman212, appreciate it!
its LHD, i will buy a set of this filter back home hopefully this xmas vacation.
Old Oct 26, 2010 | 07:00 PM
Well I looked today just for my own reasons....just a rectangle? 11.575 in by 3.779 in...thickness 1.181. Google Wix filters and you can look it up pn 24752-two per box-superceeds pn 24782-one per box.
Old Oct 26, 2010 | 11:40 PM
great! appreciate your effort.
Old Oct 27, 2010 | 09:04 AM
djalmab's Avatar
Default Similar happened to me...
Originally Posted by darkgreen18290
Yesterday I checked my cabin air filter and I’m surprise that there are no filters in the box which I believe there should be two small filters. So I called up the local dealer here in UAE (I’m an Expat, working here for about 2 years now) the agent told me that only 2006 model and up are equipped with cabin filter.
Now my question is how dangerous of not having a set of cabin air filter in this dusty country?
Regards,
Something similar happened to me.. I have a 2006 that the CAbin air filter box was there but the filter was not there. I am in Brazil.. The car was with me since brand new.. It seems that honda forget some stuff when they ship cars WW.. Mine was made in Mexico..
Old Feb 18, 2011 | 08:53 PM
jpulone's Avatar
Where is the cabin air filter on 2006 Accord and how to replace it?
Help is always appreciated.
Old Feb 18, 2011 | 11:19 PM
  #17
Instructions should be in the owner's manual.
Google search term below. Its a YouTube video showing how to do this. Its very simple to do.
axqD4kSORG4
Old Feb 19, 2011 | 06:43 PM
  #18
Open the glovebox and empty it. Unhook the spring/shock thingie from the side. You might also have to press the sides of the glovebox to unhook it. You want the glovebox to hinge all the way down so you can get at the air ducts that are hidden by it.
There's a wide slot with clips to open the cover. The filter slides out like a drawer. Replace the paper element & put it all back.
Old Feb 26, 2011 | 10:31 PM
  #19
muffinman617's Avatar
since the 1999 accords have a cabin filter does this mean that the 98s do also? i could have sworn i looked in the glove box and didnt see any filter housings.
Old Feb 27, 2011 | 11:13 PM
  #20
You have to remove the glovebox & look at the blower housing & air ducts. I think on the 98-02 the filter is behind a vertical opening.
