Caliper replacement
Old Jan 25, 2009 | 09:36 AM
coolbrze's Avatar
Default Caliper replacement
I havea '94 Accord LX and need to replace the front brake pads & probably calipers as the pads only wear in one corner bad and are griding now. Can someone give me a rundown on how to replace the calipers? Any help is greatly appreciated!
Old Jan 25, 2009 | 02:35 PM
hondadude's Avatar
Default RE: Caliper replacement
Your description of the problem sounds more like one the slider pinsis frozen.
I'd check that first before replacing the calipers
Old Feb 1, 2009 | 08:16 AM
coolbrze's Avatar
OK, how do I check it and how do I fix it, grease? Thanks!
Old Feb 1, 2009 | 08:35 AM
Any aftermarket shop manual; Haynes or Chilton will describe the procedure to inspect calipers and slide pins.
You can download a 94-97 manual from Online Manuals FAQ links.
Search is now working and there are some good posts and pics on replacing the rotors, if that is necessary. Replacing rotors requires a bit of work to access the bearing hub which traps the rotor. Again there is info in the DIY FAQ's.
cukaracha
Sep 26, 2014 06:25 PM
tdockdur
Jan 23, 2011 08:55 PM
19962door
May 17, 2010 02:06 PM
wardykid23
Oct 9, 2007 11:48 AM
val
Oct 30, 2006 03:12 AM
