calliper pin grease
Old Mar 6, 2010 | 08:34 AM
EXV6NIGHTHAWK's Avatar
Default calliper pin grease
I stopped by the dealership to get some calliper grease, and the guy hands me some super hi temp urea grease. Is this calliper grease? I want to use this on the pins, for my next pad change.
Old Mar 6, 2010 | 09:24 AM
petef23a's Avatar
yeah that would probably work. because the calipers get really hot so, yes
Old Mar 6, 2010 | 09:36 AM
Dont know what he gave you cause I never heard of urea grease, but when you go to get your pads ask your parts man for a tube of caliper pin grease and then you'll know what it is for sure..
Best Advice..read the tube he gave you ...
Old Mar 6, 2010 | 09:59 AM
It's not in a tube, but in a plastic jar. There is nothing on the container saying what it's for. I'm guessing they didn't have any calliper grease, so he just gave me the urea grease and said no charge. I hear this is expensive/synthetic grease. The service manual says to use this grease for the throttle cable end (throttle link).
Old Mar 6, 2010 | 12:16 PM
kris_loehr's Avatar
The Honda dealership I worked at used the grey anti-seize on the pins and back of the pads.
Old Mar 6, 2010 | 12:46 PM
Lightbulb Yes Kris
And that's what Ive been using for 45 years or so!
Old Mar 6, 2010 | 02:04 PM
hondadude's Avatar
Urea grease is good, it was originally designed for use on the throw out bearing, where it slides on the trans shaft.
It will stand up to high temps of the brake caliper.
My issue with anti-seize, [I know people love it] is that it seems to get sorta 'Gluey' after it has been under high heat and the solvent/liquid cooks out of it.
Old Mar 6, 2010 | 03:06 PM
I always thought the anti-seize was only for the pad backing and shims. That's what I used it for. I didn't grease the pins the first time, but I want to do it the second time around. Since the grease says "super hi temp" and it's used for super important areas, I figured it would be well suited for calliper pins. Thanks guys
Old Mar 7, 2010 | 01:14 PM
That urea grease is what the Helm book calls for. I've been using some silicone brake grease I got at AutoZone or someplace like that.
Old Mar 7, 2010 | 04:12 PM
Thanks for the vote of confidence. Now I can forget about going looking for more specific "brake" grease.
wenmang
Jun 6, 2014 07:20 PM
jkowtko
Oct 28, 2012 09:48 PM
mck52689
Jul 17, 2007 05:08 PM
besteffe
May 20, 2007 12:56 AM
im4an2idiot0
Jun 17, 2006 04:19 AM
