Can someone tell me what this is?
Old Mar 10, 2008 | 08:48 PM
sokat89's Avatar
Default Can someone tell me what this is?
There are 3 wires converging into a detachable clip on top of the intake area near throttle body. u can see it int he picture below. does anyone know what this is for and what would happen if it was removed?
[IMG]local://upfiles/15332/E858597F697F49358AA3A5C07C7FF246.jpg[/IMG]
Old Mar 10, 2008 | 09:15 PM
thirdgoat's Avatar
Default RE: Can someone tell me what this is?
[align=left]
Looks like the Manifold Absolute Pressure (MAP) sensor...
you will probably set off the Check Engine Light... may or may not run correctly, poor fuel economy... why would you disconnect it???
[/align]
Old Mar 10, 2008 | 09:49 PM
sokat89's Avatar
haha idk i was just messing around but i put it rigth back and the cel did go off. dammit. but i put it back, shudnt the light go off now?
Old Mar 10, 2008 | 09:53 PM
Some things that set off the CEL will take a few driving cycles before the CEL clears.
Butafter the CEL goes out,I thinkthe error is still stored for some period of time. Resetyour ECU. That way the MAP sensor error won't be stored to confuse the mechanic when something else goes off.
Old Mar 10, 2008 | 10:49 PM
sokat89's Avatar
how do i reset the ecu? i dont wanna go around experimenting again because this problem only came into existence as a result of that.lol
Old Mar 10, 2008 | 11:02 PM
Year?? I don't recognize it absolutely from the picture.
Any year you can reset it by disconnecting the battery, but then you'll need the stereo security code & reset your clock.
6th-gen ('98-'02), you can pull the #13 fuse in the right-end of the dashboard. That fusebox is near the right-front door hinges. Other years it's located somewhere else, orlabeled as the back-up fuse or something like that.
Old Mar 10, 2008 | 11:56 PM
sokat89's Avatar
its an 07 SE v6 auto
Old Mar 11, 2008 | 09:08 AM
00AccordLX5spd's Avatar
Registered User
Just make sure you know the radio security code (in your owner's manual) and disconnect the battery.
thirdgoat was right, that was the MAP sensor
jcombs
Nov 14, 2013 05:18 PM
eugenechoi57
Jan 13, 2013 04:19 PM
fasteddie83
Jul 4, 2011 02:47 PM
Boogie
Jun 6, 2011 09:09 PM
