cant get my a/c to seal up worth ****
Old Jan 14, 2006 | 11:20 PM
lightshow's Avatar
Default cant get my a/c to seal up worth ****
a/c line that connects to the evaporator must be leaking, anyone have a good suggestion to seal it up? i live in az and im going to need ac very soon.
lightshow
Old Jan 15, 2006 | 07:41 AM
deserthonda's Avatar
Default RE: cant get my a/c to seal up worth ****
ORIGINAL: lightshow
lightshow
if it is leaking you need to replace the line ....But by you saying MUST BE LEAKING sounds like you are not too sure...did you put dye in a/c system and you saw a leak from line ?? Did battery acid fall on it and eroded the line ??
by the way ,where in AZ do you live ??
Old Jan 15, 2006 | 06:48 PM
lightshow's Avatar
well i had a leak in my old evaporator, so i just put a new one on, there arnt any other leaks in the system, so i just figured that it has to be one of those two line that go to the evap. i live in tempe, az right off the 101 and university.
lightshow
Old Jan 15, 2006 | 11:48 PM
ORIGINAL: lightshow
lightshow
sorry buddy but i am misunderstanding you ...............you thing that 1 of those 2 lines is leaking?? but there are no other leaks in the system,,,,,,,,,than, i am assuming you think you have a leak,,,,,,did you charge sytem and freon leaked out >>? did you put dye in the system and it showed around those lines ??
Old Jan 16, 2006 | 07:24 AM
lightshow's Avatar
yea no dye yet but yea i charged the system and it leaked out. well im assuming that it leaked out because now the compressor wont turn on after having it charged for one day. i guess there may be an outside chance that when i filled it up it was at a higher temperature and now that the tempurature is lower the pressure just isnt enough to warrant the compressor turning on.
lightshow
Old Jan 16, 2006 | 10:56 PM
did you hook up a set of a/c gauges to see where the pressurs are at ??
Michael Bomes
Sep 9, 2012 03:12 PM
belay70
Sep 28, 2011 05:55 PM
fabulous010
Mar 12, 2007 02:36 AM
ivrex
Nov 19, 2006 11:29 PM
