can't open door- childproof latch/ broke outer handle
Old Jan 20, 2010 | 07:21 PM
gmckay60's Avatar
Default can't open door- childproof latch/ broke outer handle
My 2000 accord has a broken drivers side exterior handle and the childproof latch is engaged- so I can't open the door. Any tips or tricks?/??
Geoff
Old Jan 21, 2010 | 07:58 AM
I don't know, but you'll get better answers in the General Tech area. So I'll move this...
Old Jan 21, 2010 | 08:20 AM
keep_hope_alive's Avatar
i assume you're referring to the rear driver's side door.
it's tough since removing the door panels is easy, but requires that the door be open.
you can remove the handle cover (and screw), as well as the window control panel (and screw). then MAYBE try to get the top lip of the door panel off of the door. lift and pull - i don't know how easy this will be when the panel is in place, but with the screws removed it might have enough play.
then you could reach down through and disengage.
Old Jan 22, 2010 | 08:21 AM
gmckay60's Avatar
Thanks! Looks like I just need to dig in and see what happens.
Thanks!
Old Jan 22, 2010 | 08:29 AM
If you can't open the door, you might make it easier on yourself by removing the rear-seat base & back, so the WHOLE inner door panel is accessible.
Old Jan 22, 2010 | 09:23 AM
guinnessmike's Avatar
Just an idea...Is there any part of the handle that may be pulled with like a needle nose pliers? If you exterior handle is broken clean off, maybe you can try to get in through the open slot when it goes through the door to see if you can grab one of the lock actuator linkages?
Old Jan 23, 2010 | 10:40 AM
gmckay60's Avatar
Thanks guys ... good advice!
Old Jul 28, 2011 | 09:35 AM
r2b2u2's Avatar
Default Rear Honda Accord Door will not open, child loc on
Geoff
I am having the same issue. Did you manage to fix this and if so, I would greatly appreciate if you can give me some guidance
Old Jul 30, 2011 | 09:16 AM
gmckay60's Avatar
I ended up taking it to a local Honda dealership where I bought the car and they had to drill a hole in the outside handle a pull on whatever they needed to unlock the door. I was very fortunate that the dealer was very responsible. It was a used car I had bought a month earlier with no warranty yet they only charged me for the part and not the Labor! Brew Honda in Longview Texas is a Quality dealership.
jza240sx
Apr 30, 2013 04:14 PM
nismogrendel
Feb 7, 2013 07:03 PM
RedLineZ_05
Oct 18, 2012 09:24 PM
g22cd5
Nov 5, 2010 01:29 AM
