Car doesn't know when door is opened - HELP!
Old Aug 10, 2009 | 01:29 PM
DAMc's Avatar
Default '03 Accord doesn't detect door being opened - HELP!
Hello,
I am new to the forum and have searched for this, but haven't found a reference (maybe I am wording something wrong). This seems strange since this same issue occurred on the passenger side of the car 2 years ago and the dealer fixed it.
I have a 2003 Accord EX that does not detect when the driver's door has been opened. I know this because the dome light does not come on and the car re-locks the door after 30 seconds even though the door is open.
I don't know what the dealer did back then, but I am trying to avoid a trip to the dealer this time as money is tight. Any help is greatly appreciated!
Thank you,
Dave
___________________________________________
2003 Accord EX V6 Sedan
Old Aug 12, 2009 | 08:50 AM
DAMc's Avatar
As nobody has responded yet, perhaps this is a rare issue. However, if someone can shed some light on how the car detects when the door is open, I may be able to trace it myself.
It seems to me it might be a ground wire or something similar. Any thoughts on that?
Old Aug 12, 2009 | 09:47 AM
Check the door switch, located in the door-jamb. Usually those things have one wire & they complete the circuit to ground when you open the door. Wire connection loose/dirty/corroded?
I can't find which parts picture that shows up on...
Old Aug 12, 2009 | 01:01 PM
DAMc's Avatar
I was looking for that switch myself yesterday and couldn't find it. On any previous car I had it was on the front pillar where the hinge connects. Does Honda put it somewhere else?????
Usually that switch is a spring loaded button that when pushed in makes the connection, is it different in Honda?
This is the first Honda I have owned so I am asking some dumb questions. Sorry for that.
Dave
Old Aug 12, 2009 | 02:59 PM
In the other doorjamb, the rear edge of the door. Maybe sorta low? It has a rubber boot over the switch button.
They put it there so it goes off even when the door is open by only a fraction of an inch.
Old Aug 12, 2009 | 03:45 PM
DAMc's Avatar
Great! I found it. I guess the philips head screw under the cover directly above is what releases it. I will give it a try. Probably a fairly cheap part if it needs replacing in any case.
I appreciate the help.
Dave
MSC71
Nov 23, 2019 05:28 PM
dudejoe
Feb 12, 2012 07:29 AM
N1Accord
Mar 24, 2011 11:27 AM
brntrt62
Oct 26, 2008 08:27 PM
