Car Fails to Start
Old Sep 18, 2013 | 02:18 PM
abemathew's Avatar
Default Car Fails to Start
Hi Folks,
My 2005 Honda Accord EX refuses to start. Have a master and a valet key. When either key is used the usual icons light up and the green key light blinks twice. Car does not crank at all. When the key is removed, the key light blinks five times. The brake pedal doesn't give- is like a stone; can't shift out of park. Disconnected the battery- reconnected after 20 mins- same results.
HELP!
Thanks
p.s. My first post here. Dont know any thing about car mechanics.
Old Sep 18, 2013 | 02:24 PM
I moved your post to a new thread. Read forum rules and don't post a new question to an existing thread, even if subject is similar.
Old Sep 19, 2013 | 05:25 PM
Start with checking the battery and the battery connections.
Did this start all at once or was there some work done just prior to this?
Old Sep 20, 2013 | 12:28 PM
abemathew's Avatar
Thank you poorman212 for the response. The problem started all of a sudden. The battery is good (head lights, horn, etc. are all working). I did disconnect, clean the connections and terminal and reconnect. Doesn't the five blinking of the key icon indicate that the key is recognized by the immobilizer? Am wondering if it is an ignition switch or the starter problem - could it be?
Abe
Old Sep 21, 2013 | 07:27 AM
The fact the starter is not spinning the engine has me with an electrical issue, could be the electrical part of the ign switch. However it could be other things.......interlock, fuses, ect.
Is this an auto or manual trans?
Do you have a testlight or voltmeter to do some testing?
Old Sep 22, 2013 | 02:31 PM
abemathew's Avatar
It is 2005 EX/AT- has 83K miles on the clock.
Do you have a testlight or voltmeter to do some testing? - NO
What fuses should I check?
Thanks.
Old Sep 23, 2013 | 06:35 PM
In the underhood fuse box (assuming 4 cyl here). #23 50 amp fuse feeds the ign switch. Again a voltmeter or test light would be nice to be sure it is ok....you can look thru the clear window on top and "see" if it is blown......I'm almost blind so I can't do that.
Next, there should be a "shift release" on the console....you insert a key into the slot and you should be able to move the shifter. Move the shifter to "N" and try to start. If nothing, slightly push/pull the shifter while trying to start.....
From there, without a test light or voltmeter I'm not sure where to go.
Was there any recent work done to the car?
brian1012
May 10, 2012 02:21 PM
irhunter
Oct 8, 2011 09:47 AM
bovinedung
Aug 10, 2010 05:17 PM
Honda Enthusiast
Aug 8, 2010 09:43 PM
darknessfalling90
Sep 7, 2008 08:15 PM
