Ignition stuck at III without key
Old Sep 22, 2013 | 06:42 PM
Tex_hooper's Avatar
Default Ignition stuck at III without key
I turned the ignition to start without the key inserted all of the way. It started but would not turn back to II. This is on a 1981 accord. I had to stall it in 3rd and then uplug the battery. Is there any easy way to unlock the cylinder or do I need to replace the whole assembly?
Old Sep 23, 2013 | 06:43 PM
Sounds like time for a new key switch. You could try some lube in the cyl and work it with the key .
Many moons ago I had the switch on a 81 3 dr hatch go bad. I have to drive it for a few weeks by hot wiring the car.....sucked when my knee hit the wires and the car shut off or bumped the starter wire to the hot wire
dharwood
Aug 3, 2013 12:51 PM
cchandler
Jan 23, 2013 11:27 PM
AKcord
Oct 15, 2006 07:43 PM
brofrank
Jun 9, 2006 09:16 AM
brofrank
Feb 13, 2006 02:58 PM
