Car Performance, Accord 95 Auto
Old Sep 14, 2015 | 06:23 PM
mortuzahasan's Avatar
thanks Jim for your valuable input, much appreciated
Old Sep 21, 2015 | 07:36 PM
there was a leak in coolant hose from heater control valve to engine, tried to replace and Oh God, broke the damn valve, found one in junk yark and replaced the heater control valve, bleed coolant. radiator all okay now.
but......
at stop or idle, radiator fan comes on every 30 seconds ( i tested it with stopwatch, lol), weather is 72 Fahrenheit, is it normal? should the radiator fan comes on this frequent?
Old Sep 22, 2015 | 05:33 AM
Turtlehead's Avatar
Originally Posted by mortuzahasan
got some leak near timing belt cover area, i regularly check oil dip stick, when i do highway drive, before going i top up the oil upto upper mark, after driving i check next day and the oil goes to lower mark, why i loose oil on highway drive? i regularly clean PCV valve.
Is there oil dripping from the bottom drain hole on the lower t-belt cover? There is a common leak on that engine which is the balancer shaft seal which has a service bulletin posted for it. If the leak is coming from under the cover it is either that, the crank seal or the cam seal. If you remove the upper cover for the cam you will be able to see both the cam and balancer shaft seals. If the are dry then it is likely the crank seal. Seldom does the seal for the balancer gear box leak, but don't rule it out.
Old Sep 22, 2015 | 02:03 PM
Fan running every 30 seconds seems like too much, but the fan is also controlled by the air conditioner. Turn OFF the AC - also switch the direction of the air away from the windshield/defrost. I think in the defrost position it forces the AC to run.
nxgtrsim
Jun 18, 2011 04:51 PM
Havok89
Apr 22, 2010 02:06 AM
revurg
May 22, 2008 02:24 PM
thunder_x
Oct 20, 2006 03:43 AM
lightshow
Jan 9, 2006 10:00 PM
