Car sat for a year now has surging idle
Old Oct 8, 2022 | 03:49 PM
soup7racing's Avatar
Default Car sat for a year now has surging idle
So my car had sat for a little over a year and now that I’ve got it running I’ve got a surging idle issue. I took off the IAC valve and let it soak and cleaned it now it moves nicely inside with no change.
is and 03 accord with 178k and 2.4l 5spd
Old Oct 8, 2022 | 04:48 PM
Some items come to mind.
Air in the cooling system can cause idle problems, so when the engine is cool, remove the radiator cap, top off the radiator if necessary, the run the engine to allow any air to escape with the radiator cap off. Look for any vacuum hoses that rotted as that can cause an idle issue.
Other items are to scan for any codes. Maybe a rodent chew into some wiring. Look in the air filter housing and around the engine for any nests.
Old Oct 9, 2022 | 07:28 AM
So I let it run a for a bit yesterday with the cap off didn’t get many bubbles but the surging continued, it’s not actually throwing a code yet which is surprising. I do have a new IAC sensor coming for Monday. Thank you for the reply I’m going to have to search with a fine tooth comb and see if something’s disconnected somewhere
eckhart
Sep 30, 2012 08:52 AM
Cweaver016
Oct 3, 2010 10:14 AM
jamrock
Nov 7, 2008 09:20 PM
dantegl36
Aug 28, 2007 09:33 AM
89HondaLegend
Jul 5, 2006 02:02 AM
