CD5 surging idle help
Old Nov 7, 2008 | 05:24 PM
jamrock's Avatar
Default CD5 surging idle help
i need help with my cd5 the idle is surging idle.. i check the diy page but i only found instruction and pick for cb7 any on knows where i can find the info for a cd5
Old Nov 7, 2008 | 05:26 PM
94accordexl's Avatar
Default RE: CD5 surging idle help
have you cleaned/inspected the iacv (idle air control valve) on the backside of the intake manifold??
Old Nov 7, 2008 | 05:30 PM
go to page five at the very bottom (idle hunt) there is a disscussion there
Old Nov 7, 2008 | 05:31 PM
jamrock's Avatar
no wat do i jus take it off and spay it with some tb cleaner??
Old Nov 7, 2008 | 05:45 PM
thats what i do...i have to do mine every month[:@]
Old Nov 7, 2008 | 06:21 PM
jamrock's Avatar
i have another question which one n the holes in the tb is which.. becuz wen my car is warmed up there is still air going through the top hole is that the iac or the fatv
Old Nov 7, 2008 | 07:30 PM
The top hole goes to the IACV, the bottom one goes to the FITV.
The bottom hole should have very little vacuum when the car is warmed up. If you plug that hole with your finger and the idle stabilizes, then your FITV is the problem. The repair is pretty simple.
This site shows how to fix both the FITV and IAC. http://honda-tech.com/zerothread?id=1844067&page=1
here is another link for the FITV https://www.hondaaccordforum.com/arc...s-95855-1.html
For the FITV, you basically unscrew and clean it out with throttle body cleaner, then screw in the valve until it is snug. The IAC, you clean it out with throttle body cleaner.
Old Nov 7, 2008 | 09:20 PM
ORIGINAL: PAhonda
[sm=shades.gif]+1 PAHONDA
philbrous
Sep 21, 2013 10:30 AM
kr95
Mar 25, 2008 07:13 PM
gsrgofass
Dec 14, 2006 10:43 AM
wanderer63
Nov 23, 2005 01:17 AM
kwiggers
Mar 16, 2005 07:29 PM
