Sponsored by:
Sponsored by:
CD5 surging idle help
Old 11-07-2008, 05:24 PM
jamrock's Avatar
Default CD5 surging idle help
i need help with my cd5 the idle is surging idle.. i check the diy page but i only found instruction and pick for cb7 any on knows where i can find the info for a cd5
Old 11-07-2008, 05:26 PM
94accordexl's Avatar
Default RE: CD5 surging idle help
have you cleaned/inspected the iacv (idle air control valve) on the backside of the intake manifold??
Old 11-07-2008, 05:30 PM
go to page five at the very bottom (idle hunt) there is a disscussion there
Old 11-07-2008, 05:31 PM
jamrock's Avatar
no wat do i jus take it off and spay it with some tb cleaner??
Old 11-07-2008, 05:45 PM
thats what i do...i have to do mine every month[:@]
Old 11-07-2008, 06:21 PM
jamrock's Avatar
i have another question which one n the holes in the tb is which.. becuz wen my car is warmed up there is still air going through the top hole is that the iac or the fatv
Old 11-07-2008, 07:30 PM
The top hole goes to the IACV, the bottom one goes to the FITV.
The bottom hole should have very little vacuum when the car is warmed up. If you plug that hole with your finger and the idle stabilizes, then your FITV is the problem. The repair is pretty simple.
This site shows how to fix both the FITV and IAC. http://honda-tech.com/zerothread?id=1844067&page=1
here is another link for the FITV https://www.hondaaccordforum.com/arc...s-95855-1.html
For the FITV, you basically unscrew and clean it out with throttle body cleaner, then screw in the valve until it is snug. The IAC, you clean it out with throttle body cleaner.
Old 11-07-2008, 09:20 PM
ORIGINAL: PAhonda
[sm=shades.gif]+1 PAHONDA
philbrous
09-21-2013 10:30 AM
kr95
03-25-2008 07:13 PM
gsrgofass
12-14-2006 10:43 AM
wanderer63
11-23-2005 01:17 AM
kwiggers
03-16-2005 07:29 PM
Quick Reply: CD5 surging idle help
