car shuts down some times
Old Dec 30, 2009 | 11:44 AM
dmalay1's Avatar
Default car shuts down some times
I have a 1999 Honda Accord, stick shift. I have had this problem for a while now where my car just shuts down.
This usually happens when the engine is cold (it has happened when I have been driving around for a while too). and it always happens when I go from a higher gear (4th or 5th) to neutral. So lets say I am cruising at around 40 mph and I see a stop sign. So I press the clutch and shift the gear from 4th to neutral. As soon as I do this, the engine just stops (all lights light up on the dashboard and the rpm goes to zero)
What would be the reason for this? Like I said it doesnt happen all the time but it does happen often enough for me to be worried.....
Thanks,
Old Dec 30, 2009 | 01:34 PM
mcnoople's Avatar
Does it do it if you don't shift to neutral on decel? If you just coast down in gear foot on the clutch does it do it?
I would clean the throttle body. Those accords are prone to gumming the throttle body with a thick carbon goo. I don't know if that will fix anything but sometimes they can act a little strange when they are gummy. To clean it you take off the rubber boot (1 screw style hose clamp). ENGINE OFF open the throttle and use a clean rag with carb/throttle cleaner to wipe the inside of the bore of the throttle body.
Old Dec 31, 2009 | 07:42 AM
dmalay1's Avatar
Usually it happens when I move to neutral. But there are times when it has happened when I leave it in gear and just press the clutch.
I will check on what you have said here. Any other suggestions?
Thanks,
Old Dec 31, 2009 | 04:04 PM
It could be a flaky ignition switch. Try shaking the key when the car is running to see if it stalls.
Old Jul 16, 2012 | 02:58 PM
dmalay1's Avatar
Got this fixed a while ago (forgot to post here). The problem was a faulty EGR valve.
shook
Jan 26, 2012 02:52 PM
njmodi
Dec 16, 2011 10:06 PM
Rwydeven
Jun 29, 2008 12:04 PM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
sillemij
Aug 21, 2007 10:51 PM
