Car starts and runs for 3-5 secs then cuts off
Old May 18, 2014 | 11:19 AM
tdsilk's Avatar
Default Car starts and runs for 3-5 secs then cuts off
Hello,
I have a 1994 Honda Accord EX 4 cylinder that cranks then shuts off after a few seconds. I've checked the gas and the main fuel relay. The relay appears to be working fine although when I look at it I'm not sure if one of the component connections (see connection port CIRCLED IN RED) is correctly missing. I ran some test on the relay and it seems to check out. I also looked online and couldn't find a similar relay to see what it should look like. Any ideas on this would be helpful?
Troy
http://www.troyldavis.com/honda/fuelpumprelay.jpg
Old May 18, 2014 | 08:04 PM
Does the engine restart immediately?
Suggest turning keyswitch to On and listening carefully for fuel pump in tank to come on for 2-3 secs and go off. This is normal. If you don't hear this sound then starting is unlikely.
It may be necessary to measure fuel pressure to determine if loss of fuel pressure is causing engine to stop. If no loss of fuel pressure, then loss of spark is problem.
Alternatively, you could rig a timing light to monitor spark on one cylinder and see if light keeps flashing (spark) when engine shuts down. If yes, then fuel delivery is problem.
Old May 19, 2014 | 03:03 PM
tdsilk's Avatar
Yes. It restarts immediately. It just stalls shortly after. I will try a few of the test.
Thank You!
Old Jun 7, 2014 | 10:39 PM
tdsilk's Avatar
update: replaced the fuel pump and that appears to have corrected the problem.
Rachelcorina
Mar 26, 2015 02:14 PM
chris30721
Jan 6, 2011 08:06 AM
irhunter
Apr 5, 2010 07:34 PM
danielwebb
Apr 5, 2010 08:58 AM
Accord Pete
Jan 31, 2010 02:50 PM
