The car vibrates between the speed of 50 to 60 MPH
Could be due to wheel balance, tire rotation issues, uneven tire tread, wheel bearing failure Torque converter problems and so on. Has the vehicle ever been in an accident? When was the last time you got new tires or had them balanced and rotated?
a bad alignment will not make the car shake at hwy speeds ,a bad alignment will cause a pull or uneven tire wear ,,, most likely you got tires out of balance, bent rims, worn suspension parts, I would have the wheels balanced first ,,
look in the DIy section there is a write up on this
Alignment can and will cause your car to vibrate. Poor alignment will slowly but surly cause funky wear on your tires and could create choppy tread. I agree that worn suspension parts. Perhaps the sway bar bushings are worn. I've recently changed mine due to a considerable amount of road noise in the cabin and some vibration traveling through from the in need of replacement tires. The job was very easy and improved the ride a great deal, plus, it stopped that 'clunk' I heard when I would hit the slightest crack or whatever in the road.
I bought the car about 2 weeks ago. i just got the wheel alignment done... I guess the wheels are not too bad...They would last for this summer.... This car has got a clean title....
let me say it again,, an out of specs alignment WILL NOT cause a car to shake at hwy speed or any speeds,, It will cause tire wear ( which in turn can cause noise or possibly a shake depending on how worn they are ) or create a pull,, thus it is not an out of specs alignment but bad tires ......you can have an out of specs alignment with good tires and not feel any vibration at all
ABHISHEK05ACCRD
Jan 30, 2012 11:27 AM
ReadyToRetire
Sep 15, 2010 08:54 AM
vmysore
Aug 8, 2008 09:25 AM
