Car won't start
Old Sep 8, 2008 | 02:57 PM
charles1313
Default Car won't start
I have a 97 Accord. It starts and runs perfect when I first start it up. If I drive it for a half hour or 45 minutes and then turn it off it won't start. It does not make a sound when I try to start it, all power still works fine. If I let the car sit and cool down for about 45 minutes it starts right up as nothing was wrong.....Any suggestions?
Old Sep 8, 2008 | 03:18 PM
cjdm98's Avatar
Default RE: Car won't start
I had the same problem on my GS-T. Drove for like 10 min then wont start again... well what i did was get a simple electrical wire,gauge doenst matter, and connect it to the starter and then connect the other end to thepositve post, should start, if not then battery,and or starter is shot. Or even the starter switch.
Old Sep 8, 2008 | 04:31 PM
patrickz's Avatar
maybe a bad connection somewhere? check for shorts. im no a car expert, im just a guy with an opinion. My car woulnt even start for a while, then my friend took a look atit and it turned out there was oil inside the distributor cap. a no cost fix. check through eveything yourself and have a car friend look at it. it will save you lots of money. i saved 100 dollars.
Old Sep 8, 2008 | 05:06 PM
falkore24's Avatar
Look in the DIY section for things to check.
Old Sep 9, 2008 | 08:20 PM
nafango2's Avatar
time to pull out the multimeter. check power at the solenoid first and work your way to the ign switch.
Sheri6889
Jun 17, 2015 08:19 AM
Thisisnate
Aug 15, 2006 10:47 PM
motoprego
Jun 27, 2006 08:14 AM
stevec
Jun 16, 2006 10:37 PM
