car wont start?
Old Jul 27, 2013 | 07:43 PM
supradude's Avatar
Default car wont start?
kk i got a 2001 honda accord coupe it hade a f23a1 with a auto tranny i bouht a h22 auro R and iv been doing the swap iv got the motor in and extended my wiring harnes iv got all the sinsers pluged up and iv got power to the stareter all the ground are good and tight iv got dash lights and so forth but the stater want do anything the motor isint terning over the starter is good i pulled it of and jump it with a battery? on the wireing harnis from the moter to the ECU ther are 2 big connectors bye the fuse box on the left side of the injian bay 1 of thim pluged in to the h22 harnis but the othe is diffrint the 1 on the body hase 12 wires and the won for the h22 auro motor has 7 dose anyone no what i need to do only 3 wires match in color i was thanking that the one thats on the car was for all the silonuds on the auto tranny for the f23a1? please any help would bee very much thanked
Old Jul 27, 2013 | 07:57 PM
Is the ECU the original F23, or is it the H22?
You said the starter does nothing when you go to start the car. You also said you are getting power to the starter. Are you getting 12V to the small wire going to the starter when you turn the key to start the car?
Can you turn the crank by hand? You would use a 19mm deep socket and turn the engine counterclockwise.
Old Jul 27, 2013 | 08:38 PM
supradude's Avatar
no its not the origianal ecu i got the h22 auro r motor trans and ecu with wiring harnis and no i dont get any power to the small wire on the starter and yes i can tern the motor with the crank
Old Jul 29, 2013 | 06:05 PM
supradude's Avatar
ok so i got 12v to the big wire going to the starter at all times i tern the key and the little wire dos int get any voltage i was thanking my car was a auto car and iv got a mlp on the cluch peatl but i dont have a conecter to plug in to it what do i do to bye pass that?
Old Jul 29, 2013 | 06:12 PM
So you have part of the engine harness thats not connected to the chassis harness? And you are using the harness that came with the H22? Because you said you extended your harness but then you said you said there is a connector on the h22 harness that doesn't work.
Old Jul 30, 2013 | 05:41 PM
supradude's Avatar
yes the harness for the h22 hase a 7 wire connector and a 12 wire connector the 12 wire plugs in to the chassis harness and all the wires are right for it but the 7 wire connector dose not match up and on the chassi harness connector it hase 12 wires in it and only 3 colors match up and the 3 wires that match up are hot when i tern key on and so are the ones on the chassi harness?
Old Jul 30, 2013 | 06:45 PM
Would you post some pictures of these electrical connectors?
Old Aug 4, 2013 | 09:12 AM
supradude's Avatar
Old Aug 5, 2013 | 06:27 PM
supradude's Avatar
so dose these pics help?
gasface11
Jul 11, 2012 12:33 PM
notoriousflc
Jan 20, 2007 06:38 AM
ahmad89
Dec 29, 2006 07:40 PM
SHUN70
Oct 17, 2006 07:54 AM
lillum111
Sep 4, 2006 03:38 PM
