Car won't start, brake pedal stiff
Old Apr 18, 2014 | 07:33 PM
ewill23nm's Avatar
Default Car won't start, brake pedal stiff
2006 Accord lx v6
My car has power, but will not start. I think it has to do with the fact that my brake pedal is very stiff. I believe that you have to put your foot on the brake pedal in order to start the car. Any ideas or suggestions would be greatly appreciated. Thank you.
I don't know how to put my car info into my signature, sorry.
Old Apr 18, 2014 | 08:26 PM
The signature is entered under User CP. You also have to check a box to show the signature. I may do a writeup on that, because it is confusing.
Saying that your car will not start is vague. Normally, you turn the key to start the car and the starter cranks the engine. Then the engine fires up (runs on it's own) and that is when your release the key. Is your car not cranking, or firing up when you turn the key?
Also, do your brake lights turn on when you press the brake pedal?
Old Apr 18, 2014 | 08:49 PM
ewill23nm's Avatar
Car is not cranking, firing, basically not doing anything when I turn the key. My brake lights do turn on when I put my foot on the brake pedal.
Old Apr 18, 2014 | 09:21 PM
Hi Member..You can click on this link which will give you a lot of help.. on your posting.
Honda Accord Forum - Honda Accord Enthusiast Forums - FAQ: User Profile Features
Old Apr 19, 2014 | 03:21 AM
holmesnmanny's Avatar
You should first check your battery connections. Then check the voltage of your battery across the posts, and if the connections appear corroded I would check voltage on the connections side to rule out battery film on the battery posts preventing connections.
If those check out, I would then check for battery voltage at the small smarter wire that connects to the starter via a connector. It should get battery voltage when you turn the ignition to start. If you do not get voltage something before the starter is bad. If you do get voltage then the starter contacts are likely bad. You can get starter contacts for around $20 online or at larry b's starter contacts. It's fairly easy to swap them in. Or you can choose to replace the starter altogether which will be a lot more.
Rabbit
Sep 14, 2012 02:27 PM
Cody_754
Sep 10, 2012 07:15 AM
Doughboy72
Mar 29, 2011 10:31 AM
spartan615
Aug 26, 2010 06:33 AM
19962door
May 17, 2010 03:30 PM
