CAT Heat shield
Old Feb 9, 2009 | 09:05 AM
Robcie's Avatar
Default CAT Heat shield
I had an oil change done Saturday and while it was in, the tech noticed a problem with the heat shield on the cat. converter. Their price was $185! I researched the parts (upper & lower heat shields) and they came to ~ $50. Does anyone know how difficult it is to change these? Do you have to lower the whole exhaust? Can this be done by slipping the old one off and replacing it with the new one, without moving the pipes? Any input would be appreciated.
Thanks,
Old Feb 9, 2009 | 09:10 AM
What was the actual problem with the shields.
Lots of people just remove them & leave them off. Gotta be careful not to park on dry leaves, so it doesn't start a fire.
Heatshields mounting bolts can rust off. But if you want to DIY, you could even go around the shield with a big hose clamp.
Old Feb 9, 2009 | 09:13 AM
obriener2054's Avatar
just either remove old bolts and put in new ones, and if the whole shield is gone, just remove, fabricating a new one is easy too
Old Feb 9, 2009 | 10:26 AM
Robcie's Avatar
Sounds like they were just trying to make some $$$ off me! It does rattle a bit, however, I've learned to live with it. Perhaps I'll try the hose clamp idea. Thanks for the input!
Old Feb 10, 2009 | 07:37 PM
lvp0412's Avatar
I've got the big hose clamps around mine. Have'nt had any problem since.
'03 Accord 4cyl EXL
LVP in Cincinnati
scott2683
May 17, 2017 07:48 PM
bigdawg74
Aug 19, 2011 12:22 PM
hmrnmky
Feb 19, 2007 08:16 PM
Accord98Retro
Sep 7, 2006 03:57 AM
PIGGEBANK
Aug 14, 2006 01:52 AM
