Heat Shield loose
Old Feb 18, 2007 | 03:44 PM
hmrnmky
Default Heat Shield loose
I have an '05 Accord Cpe EX V6 with 11K miles and have been to the dealer twice regarding a loose heat shield. The first visit they tightened the heat shield which worked for about 2 weeks. I went in again and they replaced the heat shield which lasted for about 1 month and now it is loose again. Any ideas or suggestions about what could be causing this problem. I need to take the car in again because the of the noice the loose heat shield makes.
Old Feb 18, 2007 | 04:12 PM
poser_pilot6
Default RE: Heat Shield loose
Are you referring to the heat shield that covers the exhaust manifold?
Old Feb 19, 2007 | 01:31 AM
deserthonda's Avatar
take it back to dealer ,, and have them fix it again,, maybe they left something loose ..
Old Feb 19, 2007 | 11:24 AM
hmrnmky
I believe it is the heat shield for the exhaust manifold though the service adviser said it was near the front axel. I plan to go back and have it tightened again but just wondered if this was a common problem. Seems that the heat shield can not remain in place but either vibrates loose or however it is attached is insufficient to keep it in place.
Old Feb 19, 2007 | 12:14 PM
poser_pilot6
If its just the manifold heat shield, you could just take it off. The car will work just fine without it, and it would rid you of that noise.
Old Feb 19, 2007 | 02:28 PM
wietgr's Avatar
ORIGINAL: poser_pilot6
Every part on a car is there for a reason. If Honda didnt have to put those on im sure they would love to save that 40 cents a car. Thats a lot of money they could save. The heat shield is there for a reason and should not be removed.
Old Feb 19, 2007 | 07:22 PM
poser_pilot6
Well if you put a header on your car, you lose the heat shield anyway. So what does it really matter?
Old Feb 19, 2007 | 07:59 PM
good point Poser .. But i would Not advice it in this case,,, car is still under warranty,, if you alter anything ,you void the warranty
Old Feb 19, 2007 | 08:11 PM
wietgr's Avatar
Aftermarket headers are made of a different type of metal that disapates the heat more quickly and run cooler than factory manifolds, thats why you lose the heat shield.
Old Feb 19, 2007 | 08:16 PM
poser_pilot6
ORIGINAL: deserthonda
Even something as trivial as removing a heat shield? I dont know about warranties, I havent ever had a brand new car lol. But thats crazy. So just putting on an intake voids the warranty then?
Also, I have been running my car with stock manifold and no heat shield for about 30k miles, with no ill effects. But my car is also a fifth gen.
scott2683
May 17, 2017 07:48 PM
reeti
Dec 30, 2008 12:10 PM
Drpepper
May 23, 2007 10:03 AM
Accord98Retro
Sep 7, 2006 03:57 AM
PIGGEBANK
Aug 14, 2006 01:52 AM
