Catalytic Converter rattling
Old Jul 4, 2024 | 01:42 PM
papademuchos's Avatar
Default Catalytic Converter rattling
I have a 2000 Accord EX. The catalytic converter is rattling. Is there an easy fix? or do I need to replace it? I found some used on ebay that aren't too expensive, but before I went that route I thought I check here.
At the same time, it's throwing PP1166 & P1167 - will replace the O2 sensors as well.
Thanks in advance!
Old Jul 4, 2024 | 08:17 PM
kris_loehr's Avatar
If the shield is broken it is sold separate from what I see on the Honda dealer parts lookup.
Old Jul 5, 2024 | 06:55 AM
Thanks - I'll check the shield first
Old Jul 10, 2024 | 10:42 PM
The shield can rust at the four corners at the bolts. If you see small cracks, get two drier vent hose clamps and wrap around the heat shield and tighten down. That lasted on my TSX for years before I replaced with new shields after the studs rusted through.
PHT_GAL2
Jan 26, 2024 01:26 AM
btartus
Jul 16, 2023 12:06 PM
Cookiedivine612
Dec 31, 2021 02:34 PM
murphyb
Feb 4, 2017 05:49 PM
honDUHchick
Jan 28, 2011 07:04 AM
