Cd5 accord swapped f22a6 cd7
Old Aug 30, 2024 | 08:46 AM
AftermarketAccord's Avatar
Default Cd5 accord swapped f22a6 cb7
Hey guys, I’m hopping someone has some information for me, tomorrow I’m going to take my cb7 f22a6 motor and trans and put it in my cd5 1995 obd1. What I’d like to know is will the f22b1 front motor mount and bracket fit the f22a6? And what other modifications might need to be done it fit?
Old Sep 3, 2024 | 10:47 PM
Default Cb7 to cd5
So I have my f22a6 in my 1995 accord, Im noticing there’s going to be some wiring modifications considering it has a external coil and the f22b1 was internal. I can’t find any internal to external wiring diagrams or any threads related to this can anyone point me in the right direction?
Old Sep 4, 2024 | 10:24 AM
Is your 95 accord stock steup an EX, LX, or DX? Auto or manual? Can you provide the same information for the donor vehicle of the engine/trans?
Old Sep 21, 2024 | 08:03 PM
Default Update
So the car I’m using is a 1995 Honda Accord ex coupe with a f22b1, I swapped a 1993 Honda Accord 4dr sedan ex f22a6, there both manual and all stock for the most part, I ended up buying a f22a1 distributor with a internal coil to bypass having to rig a internal coil, so everything is plug and play, so what I’m trying to do, is make my 5th gen accord into a 4 gen accord. All I need help with, is deciphering the ecu pin out lay out, and making sure everything is where it needs to go, I know I’ll have to wire I.A.B into the harness cause the f22b1 doesn’t have them, and I know the vtec wires need to be removed as well since the f22a6 is non vtec? Once again any help is appreciated! I have one f22a6 ecu and I don’t want to fry it.
Old Sep 21, 2024 | 08:32 PM
Default Forgot to mention
I’m also using the f22b1 wiring harness and the transmission H2U5. I had to tap two new holes that were semi set up on the 4th gen transmission to use the transmission bracket from the f22b1. The reason I mention this is to make finding this information easier for the next person.
Last edited by AftermarketAccord; Sep 21, 2024 at 08:43 PM. Reason: Lack of information
eg6civic
Apr 26, 2013 03:42 AM
nickel904
Jun 3, 2010 04:29 PM
Marc B.
Jun 25, 2008 12:46 PM
808h22accord
May 2, 2008 10:06 PM
F22 to H23
Jan 24, 2008 08:04 PM
