changing auto transmission fluid
Old Feb 8, 2013 | 02:53 PM
Rilex's Avatar
Default changing auto transmission fluid
Hi, i am using accord 90, with auto transmission. I bought the car in 2010. Is still moving great. I want to find out when should i change the transmission fluid although presently there is no problem with the gear. What are the signs or test to perform to indicate that the automatic transmission is still working 100% capacity? When i engage the gear in D4 without pressing the accelerator it still tends to move forward on its own which is ok. Hope to hear from you guys. THANKS
Old Feb 8, 2013 | 06:15 PM
SLIPKANOT's Avatar
I believe there is in the manual a reccomended maintenence schedule that tells you after how many miles to service the oils and fluids. Also it should pull forward in gear with no gas. Thats just what cars do because the torque converter. My accord has over 210,000 miles on it but the tranny is relatively new as i have the 02' EX and those go out regularly lol
Old Feb 8, 2013 | 08:03 PM
UhOh's Avatar
Originally Posted by Rilex
Hi, ...
Told that we should drain and fill annually (takes 2.5 qts exactly for '97 AT) to get max lifetime from tranny.
Conventional wisdom is use Honda AT labelled fluid.
Old Feb 9, 2013 | 06:44 PM
jafriede's Avatar
When I did mine for the first time at 105K, I did a drain and fill 3 times. Kind of pricey at $8 / qt but worth it in my opinion. I plan on doing a simple drain and fill every 30K even though I think the schedule is only every 60K at least for my '05. Make sure you use a new crush washer. You can get 10 packs of them on Ebay pretty cheap.
nyaccodguy
Mar 17, 2015 06:38 PM
bjr001
Apr 27, 2011 06:46 PM
doat
Aug 23, 2009 10:45 AM
dgp1961
Jun 22, 2009 08:00 PM
HondaAficionado
Jun 9, 2009 11:46 PM
