charging problems
Old Nov 20, 2007 | 05:17 PM
tomnbarbara
Default charging problems
hello honda people
maybe someone can help me
88 honda accord 4 cl
the battery light came on when my wife was using the car
the battery died so i bought a new one then that one died also
so i bought and installed an altanator still have the battery light
my next thing to try is going to be change the pos and neg wires from the battery?
need help anybody
thanks tom
Old Nov 20, 2007 | 05:21 PM
Chiovnidca's Avatar
Default RE: charging problems
Have you checked for blown fuses?
Old Nov 20, 2007 | 05:56 PM
tomnbarbara
fuses under the hood yes not in the dash should i check the ones in the dash fuse box?
Old Nov 20, 2007 | 08:42 PM
hondadude's Avatar
With a small cheapo volt meter you can check the Alt output at the battery cables, should be around 14 volt just after starting car, but not fall below 12.5 volt.
Your original Alt probably just needed a new brush pak.
I've had bad luck with reman Alts from the parts houses, to the point of prefering a junk yard unit to the fun of swapping out the Alt 3-5 times to get a good one.
Also the carbchoke might not work on the reman units because the rebuilder doesn't care about that 3rd wire. I think it's a blue/white wire that goes to the choke on the carb and also to the Batt lite in the dash cluster.
The Batt lite in the cluster shuts off by way of equalized voltage. 12v+ and 12v+ = 0v
fishhuntandride
Jun 8, 2011 03:42 PM
pilotede320
Dec 21, 2009 07:23 AM
peewees97
Sep 3, 2009 09:50 AM
fireballer44
Aug 25, 2006 10:19 PM
fperezal
Jun 14, 2006 05:03 AM
