CHECK ENGINE LIGHT
Old Mar 13, 2008 | 03:11 AM
DA KID RYU's Avatar
Default CHECK ENGINE LIGHT
21 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
This is wat it comes out too
but i dont got vtec what do i have to do to turn it off...
Old Mar 13, 2008 | 07:30 AM
BlkCurrantKord's Avatar
Default RE: CHECK ENGINE LIGHT
Check the code again.
Old Mar 13, 2008 | 07:31 AM
I would recheck the code to be sure that it is 21. The long blink is 10 and shorts blinks are 1.
To reset the ECU, just pull the radio/backup fuse in the engine bay box for a minute. Make sure you have your radio code to reenter.
Old Mar 13, 2008 | 03:41 PM
DA KID RYU's Avatar
Nope, im not tripping i check just now...
it gives me 2 long blinks and 1 fast one...
i did it 2 times already going for the third one right now.
if i can ima put a video
yep i took the fuse out the ecu fuse out too dont got a radio and well its still the same 2 long blinks one short one
help
Old Mar 13, 2008 | 04:25 PM
How much of a pause between the 2 long & 1 short?
Code 20 = ELD
Code 1 = O2 sensor
Old Mar 13, 2008 | 06:54 PM
DA KID RYU's Avatar
Its like a 1 secong or 1 and a half second...
between spaces whythe question
o2 sensor for what...
Old Mar 16, 2008 | 11:20 PM
I got real busy fora few days...
Yeah, for code 21, there's pretty much no pause between the long & short ones.
ELD = electrical load detector. It's built into the under-hood fusebox.
Your O2 sensor is in the exhaust manifold, #6. Check for dirty/loose/corroded connections at the plug. Check for insulation rubbed off, leaving bare wires. If you can rule out that kind of stuff, then get a new sensor.
Old Mar 17, 2008 | 02:34 AM
DA KID RYU's Avatar
Thanks alotu helped me out alot...
i appreciated
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
