Check engine light
Old Nov 13, 2013 | 02:22 PM
ngen1010's Avatar
Default Check engine light
My vehicle had an emissions inspection on Friday Nov 11 and the following day my check engine light came on and has been on ever since. It was not on prior to the inspection. I drive a 2001 Honda Accord EX with a V6 engine. In the past, the check engine light would come on simply because the gas cap was not screwed on tight enough. So I would unscrew the cap and screw it back on tighter and eventually, the light would go off. I tried that fix but the light is still on and this is the 5th day. What else can I do to solve this problem?
And by the way, my vehicle did pass the emissions test.
Thanks
Old Nov 13, 2013 | 05:06 PM
Go to AutoZone or someplace like that. Have them read the error code.
Post back with the actual error code number (like P1234 or something). Don't just get the guy's explanation.
There's like 200 different things that MIGHT be causing the CEL to come on. Why guess when the parts store will read the code for free.
Old Nov 13, 2013 | 05:35 PM
Lightbulb
Thanks
Honda Accord Forum - Honda Accord Enthusiast Forums - Search Forums
You can also click on this link and it will give you loads of knowledge to read up on..
Old Nov 14, 2013 | 04:43 AM
ngen1010's Avatar
Default The engine light finally went off
Thanks so much for your advice luckily the light went off after I posted my message. But if it hadn't I would've surely taken your advice. Thanks again and have a great day
Old Nov 14, 2013 | 10:58 AM
Check anyway. Error codes are stored even when the problem "goes away". That's a big help in diagnosing those problems that never happen when the mechanic is watching.
Old Nov 14, 2013 | 11:09 AM
Jim is correct on that..check them out to see if they will be coming back to haunt you..
Old Nov 15, 2013 | 06:45 AM
ngen1010's Avatar
Ok I'll check it out and thanks again for both responses they really helped me a lot
Have a great weekend
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
