Check engine light
My vehicle had an emissions inspection on Friday Nov 11 and the following day my check engine light came on and has been on ever since. It was not on prior to the inspection. I drive a 2001 Honda Accord EX with a V6 engine. In the past, the check engine light would come on simply because the gas cap was not screwed on tight enough. So I would unscrew the cap and screw it back on tighter and eventually, the light would go off. I tried that fix but the light is still on and this is the 5th day. What else can I do to solve this problem?
And by the way, my vehicle did pass the emissions test.
Thanks
Thanks
Go to AutoZone or someplace like that. Have them read the error code.
Post back with the actual error code number (like P1234 or something). Don't just get the guy's explanation.
There's like 200 different things that MIGHT be causing the CEL to come on. Why guess when the parts store will read the code for free.
Thanks
Thanks
Honda Accord Forum - Honda Accord Enthusiast Forums - Search Forums
You can also click on this link and it will give you loads of knowledge to read up on..
78gaw
Jan 20, 2010 09:45 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
PAY1920
Jul 1, 2007 09:58 PM
