Check Engine Light '96 LX
Guys
Just a quick question. My daughter got a check engine light and we took it AutoZone to read the code. It came back as a bad numder 1 O2 sensor (not the one in the Cat), and I replaced it.
My question is: How long will it take for the Check Engine light to go off? Or is there a way to force it to reset? I'd appreciate any feedback.
Thanks!
Rich
Thanks!
Rich
What was the actual error code? There's 4 of em for the front O2 sensor. Any of those CEL codes could be caused by a bad sensor -OR- by bad wiring in the car. I'm pointing that out just in case the lamp comes back on after you reset it.
Generally, the warning lamp will quit (IF the problem is fixed) after quite a few driving cycles. But if the problem isn't fixed, the lamp will simply be triggered anew each time you drive.
78gaw
Jan 20, 2010 09:45 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
PAY1920
Jul 1, 2007 09:58 PM
