check engine light 97 accord
Old Oct 6, 2006 | 09:42 AM
MR.97ACCORD
Default check engine light 97 accord
116,000 miles car is running fine it just came on 2 days ago, most likely I am thinking oxygen sensor? where is the connector to check the codes? I will try and get out to Discount auto or Auto Zone to get a free reading.........
Old Oct 9, 2006 | 01:33 AM
Default RE: check engine light 97 accord
There's about 100 other things it might be, so why bother guessing. Get them to read the code.
But get the actual code number & post here. Sometimes the auto-parts-stores can get pretty creative with the explanation of what's causing it.
Old Oct 9, 2006 | 03:22 AM
YeuEmMaiMai's Avatar
could be EGR does the car still run fine? if it does I am going to say EGR (honda engines are KNOWN for this when milage is getting up there) if not EGR then like Jim said O2 sensor
Old Oct 9, 2006 | 08:41 AM
MR.97ACCORD
I called Honda and my car is eligible for that recall the EGR/catalytic emissions recall that includes the mini tune-up.....plugs,wires,cap,rotor, and oil change....
also the ignition switch...so taking it there this morning hopefully that takes care of it...will keep you guys posted....
mickey4live
Jul 6, 2012 08:29 AM
horsebird
Dec 18, 2011 10:44 AM
hotrod01
Nov 11, 2005 01:28 AM
