check engine light coming on
Old Oct 26, 2007 | 08:27 AM
deserthonda's Avatar
Default RE: check engine light coming on
ORIGINAL: doanutboi
your gonna need an OBD2 reader to find out the code. the plug is located behind the ashtray under the radio. after that you can just google the code and it will show you the problem.
you must not have paid attention it is a 90 accord ..
that is why i always ask people to input info about the car in the signature ...
Aboutblank, please input year and model in your sig ...Thank-you
Old Oct 26, 2007 | 08:34 AM
00AccordLX5spd's Avatar
Registered User
As dh said, OBD2 reader will not work. Your ECU should be OBD1(better anyway) and the service connector is not behind the ashtray, it's under the dash.
Old Oct 26, 2007 | 01:33 PM
Chiovnidca's Avatar
ORIGINAL: 00AccordLX5spd
1990 accords dont have a connector to jump. It should have an led on the ecu. (if it's the stock ecu)
Old Oct 26, 2007 | 01:39 PM
ORIGINAL: Chiovnidca
wooo Chio Chio my man..of course the 90 accord have the sc conector . it is located on the rt side of lower dash by the kick panel, it is a blue 2 wires connector
Old Oct 26, 2007 | 03:31 PM
aboutblank29's Avatar
so i took it to a shop and got the correct code coming out of it and it says that its the VTEC oil pressure switch.
i think its by the solenoid if im correct but i dont know how to tell if i need a new one or what
1990 Accord LX
92 JDM h22a
exeddy stage 1 clutch
Old Oct 26, 2007 | 03:49 PM
Registered User
What was the EXACT CODE NUMBER? Example: P0123
I don't ever trust what the "shop" says.
Even if I took my car to the Honda dealer, I would ask them for the exact code number.
Old Oct 26, 2007 | 04:12 PM
  #17
If you go to http://www.dhost.info/accordinfo/ and click on cylinder head valve train, a pdf opens that you can click on oil pressure switch. It goes through a test procedure. This is for a 94, but I will assume that it should be similar to the 90 accord.
I just read the previous post, I think that your car is OBDI, so the two possible codes are 21 or 22. On the top of that dhost page, there is a link for CEL code retrieval. Its very easy to do, so give that a shot. You might have to look at the ECU if the check engine light doesn't flash.
Old Oct 26, 2007 | 05:38 PM
  #18
doanutboi's Avatar
lol sorry wasnt really paying attention.
Winston Hart
Sep 7, 2013 12:32 PM
bobbybriggs01
Aug 21, 2013 06:14 PM
hotrod01
Nov 11, 2005 01:28 AM
